[原创] TI TCAN1051HGV-Q1 CAN收发器解决方案
关键词:汽车电子 CAN AEC Q100 ISO11898-2 (2016)
时间:2016-04-28 10:07:58       作者:TI        来源:中电网
TI公司的TCAN1051HGV-Q1是满足ISO11898-2 (2016)高速CAN物理层标准的收发器,满足汽车应用AEC Q100,数据速率高达5Mbps,I/O电压范围支持3.5V和5V MCU,HBM ESD 保护电压±16 kV, IEC ESD保护电压高达 ±15 kV,主要用在所有的CAN网络,重型机械ISO11783应用,和汽车与交通.本文介绍了TCAN1051HGV-Q1主要特性,框图和多种应用电路,以及TCAN10xx系列CAN评估模块主要特性和电路图.
This CAN transceiver family meets the ISO11898-2 (2016) High Speed CAN (Controller Area Network) physical layer standard. All devices are designed for use in CAN FD networks up to 2 Mbps (megabits per second). Devices with part numbers that include the "G" suffix are designed for data rates up to 5 Mbps, and versions with the "V" have a secondary power supply input for I/O level shifting the input pin thresholds and RXD output level. This family of devices comes with silent mode which is also commonly referred to as listen-only mode. Additionally, all devices include many protection features to enhance device and network robustness.
TCAN1051HGV-Q1主要特性:
AEC Q100: Qualified for Automotive Applications
Meets the Requirements of ISO11898-2 (2016)
‘Turbo’ CAN:
All devices support 2 Mbps CAN FD (Flexible Data Rate) and "G" options support 5 Mbps..
查看全文
