[原创] TI DP83867和AM3359双端口以太网PHY参考设计
关键词:网络通信 以太网 0BASE-Te 100BASE-TX 1000BASE-T
时间:2016-04-20 10:11:34       作者:TI       来源:中电网
TI公司的双端口吉比特以太网PHY参考设计TIDA-00204采用全特性的PHY收发器和AM3359 Sitara处理器,满足苛刻的工业环境EMI和EMC需求,输入电压从17V到60V,和IEEE 802.3 10BASE-Te, 100BASE-TX与1000BASE-T标准兼容,本文介绍了PHY收发器DP83867主要特性,框图,应用框图以及双端口吉比特以太网PHY参考设计TIDA-00204主要特性,系统框图,电路图和材料清单.
The DP83867 is a robust, low power, fully featured Physical Layer transceiver with integrated PMD sublayers to support 10BASE-Te, 100BASE-TX and 1000BASE-T Ethernet protocols. Optimized for ESD protection, the DP83867 exceeds 8kV IEC 61000-4-2 (direct contact).
The DP83867 is designed for easy implementation of 10/100/1000 Mbps Ethernet LANs. It interfaces directly to twisted pair media via an external transformer. This device interfaces directly to the MAC layer through the IEEE 802.3 Standard Media Independent Interface (MII), the IEEE 802.3 Gigabit Media Independent Interface (GMII) or Reduced GMII (RGMII). The QFP package supports MII/GMII/RGMII whereas the QFN package supports RGMII.
The DP83867 provides precision clock synchronization, including a synchronous Ethernet clock output. It has low latency and provides IEEE 1588 Start of Frame Detection.
查看全文
