关键词:ARM Cortex-M3 MCU 可穿戴设备 医疗设备 血糖仪 MAX326
时间:2015-12-07 14:47:21 作者:Maxim 来源:中电网
Maxim公司的MAX32600是基于行业标准的ARM® Cortex®-M3 32位RISC CPU,其最高操作频率为24MHz, 包括256KB闪存,32KB SRAM,2KB指令缓存以及高性能模拟外设.主要用在可穿戴医疗设备,皮电反应(GSR)测量,血糖仪和脉搏血氧饱和度的测量.本文介绍了MAX32600主要特性和优势,框图,开发平台MAX32600MBED优势和特性,框图,电路图,材料清单和PCB设计图.
The MAX32600 microcontroller is based on the industry-standard ARM® Cortex®-M3 32-bit RISC CPU operating at up to 24MHz. It includes 256KB of flash memory, 32KB of SRAM, a 2KB instruction cache, and integrated high-performance analog peripherals. The MAX32600 is available in the following package options: 192-ball, 12mm x 12mm CTBGA; 120-ball, 7mm x 7mm CTBGA; and 108-ball, 5.4mm x 4.3mm WLP。
MAX32600主要特性和优势:
Integrated AFE Enables Precision Wellness Measurements with Minimal Discretes 16-Bit ADC with Input Mux and PGA Up to 500ksps Conversion Rate
PGA with Gain of 1, 2, 4, and 8 and Bypass Mode
Differential 8:1 or Single-Ended 16:1 Input Mux
Internal Mux Inputs for Measuring VDDA3
Internal or External Voltage Reference Programmable Buffers for ADC and DACs
Two 12-Bit DACs and Two 8-Bit DACs
Four Operational Amplifiers
Four Low-Power Comparators
Four Uncommitted SPST ..
分享到:
