关键词:USB Type-C USB 3.0 TUSB8041
时间:2015-08-31 11:09:31 作者:TI 来源:中电网
TI公司的USB Type-C坞站提供数据和视频端口扩展和支持USB PD/Alternate模式协议的Type-C系统的充电功能,采用20V DC IN供电,包括USB3.0集线器TUSB8041,提供mini DP源连接器,以连接DisplayPort沉,协议转换器或USB集线器.本文介绍了USB3.0集线器TUSB8041主要特性,框图,USB Type-C坞站参考设计主要特性,框图,电路图,材料清单和PCB设计图.
The Type-C Dock Board is designed to help evaluate Type-C Dock implementations with video and charging support. The Type-C Dock offers data and video port expansion and a charging capability for Type-C systems that support USB PD/Alternate mode protocol. The dock comes with three downstream facing ports: two Type C DFP only ports with max of 5V@3A VBUS power, one Type-A DFP port with BC1.2 support. A DisplayPort connector is also provided for video sink connection: A direct connect to a DisplayPort monitor, connection to a MST HUB or a DP protocol converter to a monitor.
分享到:
