[原创] NXP LPC54102传感器处理和运动解决方案
关键词:ARM Cortex-M4F/M0+ MCU 嵌入式应用 LPC54102
时间:2015-11-27 11:27:06       作者:NXP       来源:中电网
NXP公司的LPC5410x系列产品是32位ARM Cortex-M4F/M0+ MCU,集成了104KB SRAM,512KB闪存,3个I2C,2个SPI,4个USART,32位计数器/定时器以及SCTimer/PWM和12位4.8MSPS ADC,具有低功耗,增强调试特性和高级支持区块等系统增强特性,适用于嵌入式应用.本文介绍了LPC5410x主要特性和优势,框图,LPC54102传感器处理/运动解决方案主要特性和优势,框图,应用软件架构图,以及LPCXpresso54102开发板电路图和PCB元件布局图,传感器屏蔽板电路图和PCB元件布局图.
The LPC5410x are ARM Cortex-M4F based microcontrollers for embedded applications. These devices include an optional ARM Cortex-M0+ coprocessor, 104 KB of on-chip SRAM, 512 KB on-chip flash, five general-purpose timers, one State-Configurable Timer with PWM capabilities (SCTimer/PWM), one RTC/alarm timer, one 24-bit Multi-Rate Timer(MRT), a Windowed Watchdog Timer (WWDT), four USARTs, two SPIs, three Fast-modeplus I2C-bus interfaces with high-speed slave mode, and one 12-bit 4.8 Msamples/secADC.
查看全文
