[原创] Atmel SMART SAM4C32智能电网解决方案
关键词:ARM Cortex-M4 MCU SoC 智能电网 智能电表
时间:2015-03-13 09:50:50       作者:Atmel       来源:中电网
Atmel公司的SMART SAM4C32 MCU是用于智能电网的系统级芯(SoC),具有两个高性能32位ARM® Cortex®-M4 RISC处理器,工作频率120MHz,高达2MB嵌入闪存,304KB SRAM和用于每个内核的高速缓存.器件集成了先进的加密引擎,防窃电,浮点单元(FPU),USB全速主/器件端口,5个USART,2个UART,2个TWI,多达7个SPI和PWM定时器,2个3路通用16位定时器.本文介绍了SAM4C32主要特性, SAM4C16/8 100引脚框图, SAM4C32 100和144引脚框图,以及SAM4C32评估板SAM4C32-EK主要特性和指标,架构图,电路图,PCB设计文件图和PCB元件布局图.
The Atmel® SMART SAM4C microcontrollers are system-on-chip solutions for smart energy applications, built around two high-performance 32-bit ARM® Cortex®-M4 RISC processors.
These devices operate at a maximum speed of 120 MHz and feature up to 2 Mbytes of embedded Flash, up to 304 Kbytes of SRAM and on-chip cache for each core.
The dual ARM Cortex-M4 architecture allows for integration of an application layer, communications layers and security functions in a single device, with the ability to extend program and data memory via a 16-bit external bus interface.
查看全文
