[原创] Infineon HybridPACK 2混合动力汽车电源模块解决方案
关键词:汽车电子 混合动力汽车 IGBT HybridPACK 2
时间:2015-02-09 09:27:17       作者:Infineon       来源:中电网
Infineon公司的HybridPACK 2是设计用于混合动力和电动汽车的汽车级电源模块,连续功率高达100kW,工作结温150°C,采用Trench-Field-Stop IGBT3三相六组配置,芯片的最大额度是800A/650V,主要用于混合动力和电动汽车的马达和/或电机逆变器,和汽车电子应用.
本文介绍了HybridPACK™ 2主要特性, 应用框图, HybridPACK™ 2混合模块驱动板主要特性,框图,电路图,材料清单和模块器件装配图以及HybridPACK™ 2混合模块逻辑板v1.2和v1.3b主要特性,框图,电路图,材料清单和模块器件装配图.
Infineon’ HybridPACK™ 2 is an automotive qualified power module designed for Hybrid- and Electric Vehicle applications from a power range up to 100kW continuous power. Designed for a 150°C junction operation temperature, the module accommodates a 3-phase Six-Pack configuration of Trench-Field-Stop IGBT3 and matching emitter controlled diodes. Maximum chip ratings are 800A/650V.
The HybridPACK™ 2 power module is based on Infineon’s leading IGBT Trench- Field-Stop Technology, which offers lowest conduction and switching losses.
The HybridPACK™ 2 power module is built on Infineon’s long time experience in the development of IGBT power modules, intense research efforts of new material combinations and assembly technologies.
查看全文
