[原创] PowerInt InnoSwitch-CH USB 10W充电器参考设计
关键词:电源管理 AC/DC转换器 USB充电器
时间:2014-11-24 09:33:18       作者:PowerInt       来源:中电网
PowerInt公司的InnoSwitch-CH系列产品具有高度集成和紧凑封装,EcoSmart能效,先进保护和安全特性,无负载的功耗小于10mW,大大简化低压大电流电源的开发和制造,主要用于智能手机充电器.本文介绍了InnoSwitch-CH系列产品亮点,框图,典型应用电路,以及RDR-420 - 10 W CV/CC USB充电器主要指标,电路图,材料清单和PCB元件布局图.
The InnoSwitch™-CH family of ICs dramatically simplifies the development and manufacturing of low-voltage, high current power supplies, particularly those in compact enclosures or with high efficiency require­ments. The InnoSwitch-CH architecture is revolutionary in that the devices incorporate both primary and secondary controllers, with sense elements and a safety-rated feedback mechanism into a single IC.
Close component proximity and innovative use of the integrated communication link permit accurate control of a secondary-side synchronous rectification MOSFET and optimization of primary-side switching to maintain high efficiency across the entire load range. Additionally, the minimal DC bias requirements of the link, enables the system to achieve less than 10 mW no-load in challenging applications such as smart-mobile device chargers.
InnoSwitch-CH系列产品亮点:
Highly Integrated, Compact Footprint ..
查看全文
