[原创] ADI ADP5090超低功耗升压稳压器解决方案
关键词:太阳能电池 电源管理 DC/DC转换器 ADP5090
时间:2014-11-10 09:20:07       作者:ADI       来源:中电网
ADI公司的ADP5090是超低功耗升压稳压器,可以转换光伏电池板或TEG的DC电源,对锂电池,薄膜电池,超级电容和传统电容以及所有小型电器和无电池系统进行到底充电.能对16uW到200mW收获电源进行有效的转换,而工作损耗小于1uW.输入电压80 mV 到3.3 V,主要用于光伏电池能量收集,TEG能量收集, 电池稳压器,.自供电的无线传感器设备,带能量收集的手持和穿戴设备.本文介绍了ADP5090主要特性,框图,多种应用电路以及ADP5059超低功耗升压稳压器评估板主要特性,电路图,材料清单和PCB设计图.
The ADP5090 is an integrated boost regulator that converts dc power from PV cells or TEGs. The device charges storage elements such as rechargeable Li-Ion batteries, thin film batteries, super capacitors, and conventional capacitors, and powers up small electronic devices and battery-free systems. The ADP5090 provides efficient conversion of the harvested limited power from a 16 μW to 200 mW range with sub-μW operation losses. With the internal cold-start circuit, the regulator can start operating at an input voltage as low as 380 mV. After cold startup, the regulator is functional at an input voltage range of 80 mV to 3.3 V. By sensing the input voltage at the VIN pin, the control loop keeps the input voltage ripple in a fixed range to maintain stable dc-to-dc boost conversion.
查看全文
