[原创] On Semi NCV7471系统基础芯片汽车电控制解决方案
关键词:汽车电子 汽车电控单元(ECU) 系统基础芯片(SBC) NCV7471
时间:2014-11-06 11:42:42       作者:On Semi       来源:中电网
On Semi公司的NCV7471系统基础芯片(SBC)集成了车体的汽车电控单元(ECU)的功能,提供和监视应用微控制器和其它负载的低压电源,通过看门狗监视应用软件,以及高速CAN和LIN收发器,是ECU成为多个通信节点或用作网关单元.本文介绍了NCV7471主要特性,框图和应用框图,以及系统基础芯片(SBC)评估板主要特性,电路图,材料清单和PCB设计图.
NCV7471 is a System Basis Chip (SBC) integrating functions typically found in automotive Electronic Control Units (ECUs) in the body domain. NCV7471 provides and monitors the low-voltage power supplies for the application microcontroller and other loads, monitors the application software via a watchdog and includes high-speed CAN and LIN transceivers allowing the ECU to host multiple communication nodes or to act as a gateway unit. The on-chip state controller ensures safe power-up sequence and supports low-power modes with a configurable set of features including wakeup from the communication buses or by a local digital signal WU. The status of several NCV7471 internal blocks can be read by the microcontroller through the serial peripheral interface or can be used to generate an interrupt request.
NCV7471主要特性:
Control Logic
- Ensures safe powerup sequence and the correct reaction to different supply conditions ..
查看全文
