Microchip PIC32MX蓝牙音频开发方案
关键词:通信技术 无线通信 蓝牙
时间:2014-06-03 10:14:42       作者:Microchip       来源:中电网
Microcchip公司的PIC32MX330/350/370/430/450/470是采用MIPS microAptiv或M4K核的32位高性能MCU,采用和16位MCU引脚/外设兼容的低成本开发工具,能缩短PIC32 MCU的上市时间,主要用在高度紧凑图像/用户接口,以太网/USB/CAN连接,多任务嵌入控制和高性能音频. 本文介绍了PIC32MX330/350/370/430/450/470主要特性,框图, PIC32MX蓝牙音频开发套件主要特性,特性图和框图,以及电路图,材料清单和PCB元件布局图.
Microchip’s 32-bit portfolio with the MIPS microAptiv or M4K core offer high performance microcontrollers, and all the tools needed to develop your embedded projects. With MPLAB® Harmony software framework, low cost development tools, and pin/peripheral compatibility from 16-bit product lines, PIC32 MCUs shorten time to market and allow your designs to grow. PIC32 gives your application the processing power, memory and peripherals your design needs!
PIC32MX330/350/370/430/450/470主要特性:
Operating Conditions
•2.3V to 3.6V, -40℃ to +105℃ (DC to 80 MHz),-40℃ to +85℃ (DC to 100 MHz)
Core: 100 MHz/131 DMIPS MIPS32® M4K®
•MIPS16e® mode for up to 40% smaller code size
•Code-efficient (C and Assembly) architecture
•Single-cycle (MAC) 32x16 and two-cycle 32x32 multiply
Clock Management
•0.9% internal oscillator..
查看全文
