ST M24SR64-Y动态NFC-RFID标签解决方案
关键词:无线通信 NFC RFID
时间:2014-02-26 11:31:08       作者:ST       来源:中电网
ST公司的M24SR64-Y是具有双接口的动态NFC-RFID标签IC,嵌入EEPROM存储器,RF协议和ISO/IEC 14443 Type A 与NFC Forum Type 4标签兼容,能与13.56 MHz RFID阅读器或NFC手机工作.本文介绍了M24SR64-Y主要特性,框图以及评估板M24SR-DISCOVERY主要特性,框图,电路图,材料清单和PCB元件布局图.
The M24SR64-Y device is a dynamic NFC/RFID tag IC with a dual interface. It embeds an EEPROM memory. It can be operated from an I2C interface or by a 13.56 MHz RFID reader or an NFC phone.
The I2C interface uses a two-wire serial interface, consisting of a bidirectional data line and a clock line. It behaves as a slave in the I2C protocol.
The RF protocol is compatible with ISO/IEC 14443 Type A and NFC Forum Type 4 Tag.
M24SR64-Y主要特性:
I2C interface
• Two-wire I2C serial interface supports 1 MHz protocol
• Single supply voltage: 2.7 V to 5.5 V
Contactless interface
• NFC Forum Type 4 Tag
• ISO/IEC 14443 Type A
• 106 Kbps data rate
• Internal tuning capacitance: 25 pF
Memory
• 8-Kbyte (64-kbit) EEPROM
• Support of NDEF data structure
• Data retention: 200 years
• Endurance: 1 million erase-write cycles
• Read up to 246 bytes in a single command..
查看全文
