ADI AD9361 3G(4G)基站收发器解决方案
关键词:通信技术 无线通信 3G基站 4G基站
时间:2014-02-25 10:58:33       作者:ADI       来源:中电网
ADI公司的AD9361是面向3G和4G基站应用的高性能高集成度的射频(RF)捷变收发器(Agile Transceiver™),集成了12位ADC和DAC,支持TDD和FDD。该器件的可编程性和宽带能力使其成为多种收发器应用的理想选择。该器件集RF前端与灵活的混合信号基带部分为一体,集成频率合成器,为处理器提供可配置数字接口,从而简化设计导入.AD9361工作频率范围为70 MHz至6.0 GHz,支持的通道带宽范围为不到200 kHz至56 MHz.主要用在点对点通信系统,毫微微蜂窝/微微蜂窝/微蜂窝基站和通用无线电系统 .本文介绍了AD9361主要特性和功能框图,以及评估板AD-FMCOMMS2-EBZ主要特性和电路图以及评估板AD-FMCOMMS2-EBZ材料清单..
The AD9361 is a high performance, highly integrated radio frequency (RF) Agile Transceiver™ designed for use in 3G and 4G base station applications. Its programmability and wideband capability make it ideal for a broad range of transceiver applications. The device combines a RF front end with a flexible mixed-signal baseband section and integrated frequency synthesizers, simplifying design-in by providing a configurable digital interface to a processor. The AD9361 operates in the 70 MHz to 6.0 GHz range, covering most licensed and unlicensed bands. Channel bandwidths from less than 200 kHz to 56 MHz are supported.
查看全文
