NXP SSL5018TE 230V 18W LED T8管灯解决方案
关键词:电源管理 AC/DC转换器 LED照明 T8管灯
时间:2014-02-21 10:31:35       作者:NXP       来源:中电网
NXP公司的SSL5018TE是集成了MOSFET的高压集成电路(IC)控制器,输入电压高达230V(AC),具有占位面积小,效率高达93%,功率因素大于0.95,总谐波失真(THD)小于20%,内部集成了多种保护功能,主要用在无调光的LED照明包括18W T-LED或更高功率的灯.本文介绍了SSL5018TE主要特性和优势,框图, PF>0.95驱动电路图,以及演示板SSL5018DB1124主要特性,电路图,材料清单和PCB布局图.
The SSL5018TE is a high-voltage Integrated Circuit (IC) controller with an integrated MOSFET for driving LED lamps in general mains non-dimmable lighting applications. The IC operates with input voltages up to 230 V (AC).
The main benefits of these products are:
• Small Printed-Circuit Board (PCB) footprint, and compact solution
• High efficiency (up to 93 %)
• High input power factor (> 0.95); Low Total Harmonic Distortion (THD; < 20 %)
• Intermediate power factor (PF > 0.7); low ripple (< 5 %); minimum external component count
• Enhanced power capability
• Low electronic Bill Of Material (BOM)
查看全文
