Cirrus CS53L30多路麦克风音频应用解决方案
关键词:消费类电子 录音机 语音识别 摄影机 数码相机
时间:2013-11-19 13:59:23       作者:Cirrus       来源:中电网
Cirrus公司的CS53L30是高性能低功耗四模数转换器(ADC),0dB增益的动态范围91dB,THD+N为-84dB,四路全差分输入和模拟可编增益放大器,主要用于语音识别系统, 录音机,摄影机,数码相机以及高挡耳机和电话系统.本文介绍了CS53L30主要特性,框图,典型应用电路以及CS53L30评估板主要特性,框图.电路图和PCB元件布局图.
The CS53L30 is a high-performance, low-power, quad-channel ADC. It is designed for use in multiple-mic applications while consuming minimal board space and power.
The flexible ADC inputs can accommodate four channels of analog mic or line-input data in differential, pseudodifferential, or single-ended mode, or four channels of digital mic data. The analog input path includes a +10- to +20-dB boost and a –6- to +12-dB PGA. Digital mic data bypasses the analog gain circuits and is fed directly to the decimators.
Four mic bias generators are integrated into the device. The device also includes two digital mic serial clock outputs. The CS53L30 includes several digital signal processing features such as high-pass filters, noise gate, and volume control.
查看全文
