TI TAS5412-Q1 双通道汽车级数字音频功放参考设计方案
关键词:汽车级数字音频 TI TAS5412-Q1
时间:2013-09-24 13:44:00       作者:TI       来源:中电网
TI公司的TAS5412-Q1是一款用于汽车头部单位和外部放大器的双通道数字音频放大器,它提供了两个通道在总谐波失真及噪声在10%以内,4Ω负载时可达到28W、在2Ω负载时可达到46W。数字PWM拓扑提供了比传统线性放大器更合理的改善效率解决方案。在典型的音乐播放条件下,这减少了一个数量级的放大器功率损耗。该设备包含一个专利的设计,提供了出色的PWM供电排斥,在严酷的电气环境共同实现汽车应用。应用实现效率高而不需要复杂的供电方案。设计允许多个设备的同步。本文首先介绍芯片的简介、特性、内部框图及应用领域,并给出相应设计方案的设计原理图、元器件列表及PCB元件布局图。
The device is a two-channel digital audio amplifier designed for use in automotive head units and external amplifiers. It provides two channels at 28 W into 4 Ω at 10% THD+N from 14.4 V or 46 W into 2 Ω at 10% THD+N. The digital PWM topology provides dramatic improvements in efficiency over traditional linear amplifier solutions. This reduces the power dissipated by the amplifier by a factor of ten under typical music playback conditions. The device incorporates a patented PWM design that provides excellent power-supply rejection in the harsh electrical environment common in automotive applications. Applications attain high efficiency without the need for complicated power supply schemes. The design allows synchronization of multiple devices.
查看全文
