ST 的面板显示解决方案
关键词:紧凑型LED控制器 STLED316S 串行3线接口 机顶盒
时间:2013-09-03 14:17:04       作者:ST       来源:中电网
Keywords: compact LED controller , STLED316S, serial 3-wire interface , STB
摘要:该STEVAL-CBP005V1示范板的方案是用于展示前面板HR21机顶盒(STB)解决方案,并设计成可以提供有出色性能功能的的LED控制器/驱动STLED316S的测试方案。
基本特点:
The STLED316S is a compact LED controller and driver that interface microprocessors to LED displays through a serial 3-wire interface. It drives LED connected in common anode configuration.
The STLED316S drives up to 48 discrete LEDs in 8 segment/6 digit configuration while functioning from a supply voltage of 5.0V. Additionally it can be used to drive 8 discrete LEDs which form a part of LED digit. The individual LEDs are wired as segments of a digit and brightness of these individual LEDs can be controlled digitally. The maximum segment current for the display digits is set through a single external resistor. Individual digits may be addressed and updated without rewriting the entire display.
方案描述:
查看全文
