Keywords:USB 2.0 Full Speed Interface 10/100 Ethernet Port TFT LCDprot
简单描述:
LPC1768 开发板可以使你快速建立起基于LPC1768的开发环境。使开发人员尽快熟悉LPC1768的各项共能,并根据开发板提供的各种应用例程,完成开发过程。
基本特征:
Color QVGA TFT LCD
USB 2.0 Full Speed - USB, USB-OTG, and USB Host
2 CAN interfaces
2 Serial Ports
SD/MMC Card Interface
5-position Joystick and push-button
Analog Voltage Control for ACD Input
Amplifier and Speaker
Up to 70 GPIO
Debug Interface Connectors
方案特点:
Standard USB connectors for USB Device, USB-OTG, USB Host and UART via USB on the MCB1700 board for applications requiring USB communications.
Dual Serial Ports
Standard DB9 connectors are on the MCB1700 for both of the LPC1700’s serial ports. Your application may use either of these ports.
Dual CAN Ports
Standard DB9 connectors are on the MCB1700 board for applications requiring CAN communications. Your application may use either or both of these ports, or they may be disabled with a configuration jumper.
100/10M Ethernet Port
分享到:
