OnSemi NCP4354A 65W空载低功耗离线电源适配器设计方案
关键词:NCP4354A 65W 低功耗离线电源适配器
时间:2013-08-12 10:31:31       来源:中电网
OnSemi公司的NCP4354A是一款为实现在空载时具有极低功率损耗应用而设计的副边开关电源控制器。该控制器具有空载探测能力和使控制器进入低功率损耗的关断模式。在关断模式期间,原边控制器关断,输出由输出电容来提供能量保持稳压输出由此消除功率消耗。在关断期间,输出电压为释放状态,输出电压被允许减少在可调整的范围内,一旦更多能量被需要,NCP4354A原边控制就会自动启动来提供所需电源。本文首先介绍NCP4354A简介、基本特性、内部框图及应用领域,并给出相应设计方案的设计原理图、元器件列表及PCB元件布局图。
The NCP4353/4 is a secondary side SMPS controller designed for use in applications which require extremely low no load power consumption. The device is capable of detecting “no load” conditions and entering the power supply into a low consumption OFF mode. During OFF mode, the primary side controller is turned off and energy is provided by the output capacitors thus eliminating the power consumption required to maintain regulation. During OFF mode, the output voltage relaxes and is allowed to decrease to an adjustable level. Once more energy is required, the NCP4353/4 automatically restarts the primary side controller.The NCP4353/4 controls the primary side controller with an“Active OFF”signal, meaning that it drives optocoupler current during OFF mode to pull−down the FB pin of the primary controller.
查看全文
