Avnet Xilinx Kintex-7 FPGA Mini-Module Plus开发方案
关键词:通信技术 网络通信 无线通信 Kintex-7 FPGA
时间:2012-07-27 10:23:16       作者:Avnet       来源:FPGA
Xilinx公司的Kintex-7 FPGA具有144GMACS DSP,能满足更高的性能而功耗是目前产品的40%,可以集成更多的硅器件,从而更容易创建差异性产品,具有更低的成本而提高了竞争性.可编程的Kintex-7 FPGA支持多种空中接口如LTE,WiMAX和WCDMA.广泛用在通信,医疗电子,3D TV,航空航天,多模式无线电等.本文介绍了Kintex-7 FPGA主要特性以及单片LTE基带(2x4MIMO)框图,手持超声波框图和IP网关视频框图与Kintex-7 Mini Module Plus开发套件主要特性,框图和板电源框图,开发套件电路图和材料清单.
Kintex-7 FPGAs let designers build in superior bandwidth and 12-bit digitally programmable analog while meeting cost and power requirements. Unprecedented 144GMACS digital signal processor (DSP) power makes the versatile Kintex-7 devices an excellent option for applications such as portable ultrasound equipment and next-generation communications. Kintex-7 FPGAs deliver peak serial bandwidth (full duplex) of 800Gbps and include CPRI/OBSAI IP cores (9.8Gbps) optimized for today’s distributed baseband architectures. The programmable Kintex-7 devices can also be easily reconfigured to support multiple air interfaces such as LTE, WiMAX, and WCDMA. For interfacing to host systems, the Kintex-7 FPGA family provides built-in support for eight-channels of PCI Express (Gen1/Gen2).
The highly efficient and affordable devices also enable designers to address connectivity and throughput requireme..
查看全文
