ZMDI ZSSC1856智能电池检测和管理解决方案
关键词:电源管理 智能电池
时间:2012-07-05 14:11:52       作者:ZMDI       来源:ZSSC1856
ZMDI公司的ZSSC1856是集成了嵌入式MCU的双路高精度18位Sigma-Delta ADC,其中的一路输入通过外接电阻测量电池电流IBAT(失调误差小于10mA,分辨率优于1mA),另一路测量电池电压VBAT(输入范围4-28.8V,精度+/-2mV)和温度,而集成的闪存则用来计算电池的状态.可编增益4-512,取样速率1Hz到16kHz,主要用在汽车,工业和医疗领域.本文介绍了ZSSC1856主要特性和优势,方框图,基本应用电路和典型应用电路.
The ZSSC1856 is a dual-channel ADC with an embedded microcontroller for battery sensing/management in automotive, industrial, and medical systems.
One of the two input channels measures the battery current IBAT via the voltage drop at the external shunt resistor. The second channel measures the battery voltage VBAT and the temperature. An integrated flash memory is provided for customer-specific soft-ware; e.g., dedicated algorithms for calculating the battery state.
During Sleep Mode (e.g., engine off), the system makes periodic measurements to monitor the dis-charge of the battery. Measurement cycles are controlled by the software and include various wake-up conditions. The ZSSC1856 is optimized for ultra-low power consumption and draws only 100μA or less in this mode.
查看全文
