Cirrus CS1631 9W离线LED驱动器参考设计
关键词:电源管理 LED驱动器 AC/DC转换器
时间:2012-05-29 10:55:30       作者:Cirrus       来源:CS1631
Cirrus公司的CS1630和CS1631是高性能离线AC/DC LED驱动器,采用Cirrus公司的数字调光控制技术和数字相关彩色温度(CCT)控制系统,能进行两路LED色彩混合. CS1630用于120VAC,CS1631用于230VAC火线电压, 主要用于可调光LED灯和LED照明,高CRI照明,离线LED驱动器和商用照明.本文介绍了CS1630和CS1631主要特性, 典型应用电路,以便及CRD1631-9W 9瓦参考设计主要特性,电路图,反激变压器和电感电路图和材料清单.
The CS1630 and CS1631 are high-performance offline AC/DC LED drivers for dimmable and high color rendering index (CRI) LED replacement lamps and luminaires. It features Cirrus Logic’s proprietary digital dimmer compatibility control technology and digital correlated color temperature (CCT) control system that enables two-channel LED color mixing. The CS1630 is designed for 120VAC line voltage applications, and the CS1631 is optimized for 230VAC line voltage applications.
查看全文
