IR IR4301 130W 2路D类音频功率放大器参考设计
关键词:消费类电子 D类音频功率放大器
时间:2012-05-29 10:53:18       作者:IR       来源:IR4301
IR公司的IR4301和R4311集成了PWM控制器和数字音频MOSFET,组成了高性能D类音频放大器,具有高峰值音乐功率输出,不需要机械的散热器,单电源或双电源工作,差分或单端输入,过流,超温和欠压保护,并具复位功能,IR4301能向4欧姆输出160W功率,IR4311能向4欧姆输出35W功率,主要用在家庭影院系统,坞站音频系统,电子音乐,卡拉OK放大器,游戏控制台,扬声器系统和通用音频功率放大器.本文介绍了IR4301和IR4311主要特性,方框图,多种连接电路和应用电路,以及采用IR4301的130W/4Ω x 2路D类音频功率放大器IRAUDAMP12参考设计主要特性,电路图,材料清单和PCB布局图.
The IR4301, IR4311 integrates PWM controller and digital audio MOSFETs forming a high performance Class D audio amplifier. As a result of fully optimized MOSFETs co-packed with a dedicated controller IC, the IR4301, IR4311 operates without mechanical heatsink attached in a typical music playback usage. High voltage ratings and noise immunity in the controller IC ensures reliable operation over various environmental conditions. A small 5x6 mm MLPQ package enhances the benefit of smaller size of Class D topology. The IR4301, IR4311 are a lead-free, ROHS compliant.
IR4301和IR4311主要特性:
 Integrated analog input Class D audio amplifier in a small 5 x 6 mm PQFN package
 High peak music power output
 No mechanical heatsink required
 Split or single power supply
 Differential or single-ended input<..
查看全文
