AKM 公司的AK4203是立体声无电容线路放大器和视频放大器,具有内置的电荷泵电路,采用单个3.3V电源,可得到2Vrms输出,并具有极好的线性度.音频放大器的THD+N为 -90dB, S/N为102dB,视频放大器的S/N为75dB(typ),放大器增益为+6dB.本文介绍了AK4203主要特性,方框图,典型连接图,评估板AKD4203-A功能和方框图,以及电路图和元件布局图.
Stereo Cap-less LINE-Amp and Video-Amp
The AK4203 is an audio stereo cap-less line driver with 1-channel video driver. It eliminates the need for large DC-blocking capacitors with a built-in Charge-pump circuit. The AK4203 achieves 2Vrms outputs with excellent linearity 2Vrms output by single 3.3V power supply. The AK4203 is available in small 16-pin TSSOP, saving the system space and cost.
AK4203主要特性:
Audio Line-Amp
Differential Input
Stereo Cap-less Amplifier (No DC-blocking capacitors required)
Line-Out level: 2.0Vrms
THD+N: -90dB
S/N: 102dB
Output gain: 6dB
Low-pass Filter: fc= 130kHz
Pop Noise Free Ground-referenced Output Video Amp
1ch Stereo Cap-less Amplifier (No DC-blocking capacitors required)
Integrated Video Amplifier (+6dB)
Input Level: 1.5Vpp (max)
分享到:
