ST STEVAL-IFW001V1 STR912FA实时以太网评估方案
关键词:通信技术 网络通信 以太网
时间:2012-02-23 10:39:52       作者:ST        来源:STEVAL
ST公司的STR91xFAxxx系列是ARM966E-S™ 16/32位闪存MCU,集成了以太网,USB,CAN,AC马达控制,4个定时器,ADC,RTC和DMA.处理器核采用哈佛架构,5级流水线,高达96MIPS性能,支持单周期DSP指令,主要用在语音处理,音频算法和低端图像.本文介绍了STR91xFA主要特性,方框图,以及STR912FA实时以太网评估板STEVAL-IFW001V1主要特性,方框图,电路图,材料清单和PCB元件布局图.
STR91xFAxxx:ARM966E-S™ 16/32-bit Flash MCU with Ethernet, USB, CAN, AC motor control, 4 timers, ADC, RTC, DMA
STR91xFA is a series of ARM-powered microcontrollers which combines a 16/32-bit ARM966E-S RISC processor core, dual-bank Flash memory, large SRAM for data or code, and a rich peripheral set to form an ideal embedded controller for a wide variety of applications such as point-of-sale terminals, industrial automation, security and surveillance, vending machines, communication gateways, serial protocol conversion, and medical equipment. The ARM966E-S core can perform single-cycle DSP instructions, good for speech processing, audio algorithms, and low-end imaging.
This datasheet provides STR91xFA ordering information, functional overview, mechanical information, and electrical device characteristics.
查看全文
