TI(NS) LM3448 TRIAC调光离线LED驱动解决方案
关键词:电源管理 AC/DC转换器 LED驱动器
时间:2011-10-11 11:44:11       作者:TI       来源:LM3448
TI(NS)公司的LM3448 是集成了600V的MOSFET的TRIAC相位调光的离线LED驱动器,应用电压范围从85VAC到265VAC,可调整的开关频率,不会出现120Hz的闪烁,能为大功率LED提供恒流,主要用于改进型TRIAC调光,固态照明,工业和商业照明以及住宅照明。本文介绍了LM3448主要特性,简化方框图,基本的TRIAC调光电路,典型LED驱动器应用电路以及多种设计案例和指标及其所用材料清单,LM3448 A19 Edison改进型评估板电路图和材料清单。
LM3448:Phase Dimmable Offline LED Driver with Integrated FET
The LM3448 is an adaptive constant off-time AC/DC buck (step-down) constant current LED regulator designed to be compatible with TRIAC dimmers. The LM3448 provides a constant current for illuminating high power LEDs and includes a phase angle dim decoder. The dim decoder allows wide range LED dimming using standard forward and reverse phase TRIAC dimmers. The integrated high-voltage and low Rdson MOSFET reduces design complexity while improving LED drive`rm factor LED drivers suitable for integrated LED lamps with very low external component count. The LM3448 also provides the flexibility required to implement both isolated and non-isolated solutions based on the Flyback, Buck or Buck-Boost topology using either active or passive power factor correction (Valley- Fill) circuits. Additional features include thermal shutdown, current limit and VCC under-voltage lockout...
查看全文
