TI CC430 6LoWPAN无线传感器网络解决方案
关键词:通信技术 网络通信 无线传感器网络 WSN
时间:2011-09-30 11:28:34       作者:TI       来源:CC430
TI公司的CC430系列是集成了RF收发器内核和超低功耗微控制器的系统级芯片,采用16位RISC架构,扩展存储器,高达20MHz系统时钟,工作电压1.8V-3.6V,CPU工作模式的功耗160 µA/MHz,待机模式2.0 µA,主要用在无线模拟和数字传感器系统,温度调节器, AMR/AMI仪表,智能电网无线网络等.本文介绍了CC430系列主要特性, CC430F613x和CC430F513x功能方框图及其典型应用电路图与相应的元器件,以及6LoWPAN 低于1GHz评估板CC-6LOWPAN-DK-868主要特性,系统框图和相应的电路图,材料清单.
The Texas Instruments CC430 family of ultra-low-power microcontroller system-on-chip with integrated RF transceiver cores consists of several devices featuring different sets of  peripherals targeted for a wide range of applications. The architecture, combined with five low-power modes, is optimized to achieve extended battery life in portable measurement applications. The device features the powerful MSP430™ 16-bit RISC CPU, 16-bit registers, and constant generators that contribute to maximum code efficiency.
The CC430 family provides a tight integration between the microcontroller core, its peripherals, software, and the RF transceiver, making these true system-on-chip solutions easy to use as well as improving performance.
查看全文
