NXP UBA2015AP 35W CFL灯电源解决方案
关键词:电源管理 CFL镇流器 管灯(TL)
时间:2011-09-23 11:38:57       作者:NXP       来源:UBA2015AP
NXP公司的UBA2016A/15/15是集成了PFC,线性调光和升压功能的600V荧光灯驱动器,包括荧光灯驱动模块,半桥驱动器,临界导通模式的PFC控制器/驱动器以及几种保护功能,主要用于通用照明的小型荧光灯和管灯驱动.本文介绍了UBA2016A/15/15A主要特性和优势与方框图, 基本的PFC应用电路图, 灯电流控制图和多种应用电路图,以及UBA2015AP 120 V (AC) 评估板指标,电路图,材料清单和PCB元件布局图.
UBA2016A/15/15A:600 V fluorescent lamp driver with PFC, linear dimming and boost function
The UBA2016A/15/15A are high voltage Integrated Circuits (IC) intended to drive fluorescent lamps with filaments such as Tube Lamps (TL) and Compact Fluorescent Lamps (CFL) in general lighting applications. The IC comprises a fluorescent lamp control module, half-bridge driver, built-in critical conduction mode Power Factor Correction(PFC) controller/driver and several protection mechanisms. The IC drives fluorescent lamp(s) using a half-bridge circuit made of two MOSFETs with a supply voltage of up to 600 V.
The UBA2016A/15/15A are designed to be supplied by a start-up bleeder resistor and a dV/dt supply from the half-bridge circuit, or any other auxiliary supply derived from the half-bridge or the PFC. The supply current of the IC is low. An internal clamp limits the supply voltage.
UBA2016A/15/15A主要特性和优势:
查看全文
