Linear LTC2997高精度模拟输出温度检测和遥控方案
关键词:工业控制 温度测量 温度传感器
时间:2011-07-19 11:57:26       作者:Linear       来源:LTC2997
Linear公司的LTC2997是高精度模拟输出温度传感器,遥控温度的精度为±1℃,内部温度测量的精度为±1.5℃,内置了串联电阻消除,工作电压2.5V-5.5V,输出增益4mV/°C,静态电流170uA,1.8V基准电压输出,主要用在温度测量,遥控温度测量,环境监视,系统热量控制,笔记本和台式电脑以及网络服务器.本文介绍了LTC2997主要特性, 方框图,以及遥控和遥测多种应用电路.
LTC2997 Features Description Remote/Internal Temperature Sensor
The LTC2997 is a high-accuracy analog output temperature sensor. It converts the temperature of an external sensor or its own temperature to an analog voltage output. A built-in algorithm eliminates errors due to series resistance between the LTC2997 and the sensor diode.
The LTC2997 gives accurate results with low-cost diodeconnected NPN or PNP transistors or with integrated temperature transistors on microprocessors or FPGAs.Tying pin D+ to VCC configures the LTC2997 as an internal temperature sensor.The LTC2997 provides an additional 1.8V reference voltage output which can be used as an ADC reference input or for generating temperature threshold voltages to compare against the VPTAT output.
The LTC2997 provides a precise and versatile micropower solution for accurate temperature sensing.
LTC2997主要特性:
Converts Remote Sensor or Internal Diode Temperature to Analog Voltage
查看全文
