NS LM3409 PFET降压控制大功率LED驱动方案
关键词:电源管理 LED驱动器 DC/DC转换器
时间:2011-06-20 11:53:23       作者:NS       来源:LM3409
NS 公司的LM3409/09HV是用于降压电流调整的P沟MOSFET( PFET)控制器,LM3409/LM3409Q输入电压从6V到42V,LM3409HV/LM3409QHV输入电压从6V到75V。PWM调光范围10000:1,模拟调光范围250:1,支持所有的陶瓷电容输出和无电容输出能驱动正向电流达5A的大功率LED,主要用在LED驱动器,恒流源,汽车照明,通用照明和工业照明。本文介绍了LM3409/09HV主要特性,方框图,多种应用电路和相应的材料清单,以及LM3409HV评估板电路图和评估板材料清单。
PFET Buck Controller for High Power LED Drivers
The LM3409/09HV are P-channel MosFET (PFET) controllers for step-down (buck) current regulators. They offer wide input voltage range, high-side differential current sense with low adjustable threshold voltage, fast output enable/disable function and a thermally enhanced eMSOP-10 package.
These features combine to make the LM3409/09HV ideal for use as constant current sources for driving LEDs where forward currents up to 5A are easily achievable.
The LM3409/09Q/09HV/09QHV uses Constant Off-Time (COFT) control to regulate an accurate constant current without the need for external control loop compensation. Analog and PWM dimming are easy to implement and result in a highly linear dimming range with excellent achievable contrast ratios.
Programmable UVLO, low-power shutdown, and thermal shutdown complete the feature set.
查看全文
