IR IRS2573D 70W HID灯镇流器解决方案
关键词:电源管理 HID灯镇流器 AC/DC转换器
时间:2011-06-14 14:00:11       作者:IR       来源:IRS2573D
IR公司的IRS2573D 是全集成全保护的600V HID控制器IC,可驱动任何类型的HID灯.器件内部电路提供了点火,预热,运行和故障操作模式.具有600V高边和低边全桥驱动器,内部的15.6V齐纳二极管箝位VCC,微功耗150uA起动.本文介绍了IRS2573D主要特性,方框图, 典型应用框图以及采用IRS2573D的70W HID灯镇流器参考设计主要特性,框图,电路图,材料清单和PCB布局图.
The IRS2573D is a fully-integrated, fully-protected 600V HID control IC designed to drive all types of HID lamps. Internal circuitry provides control for ignition, warm-up, running and fault operating modes. The IRS2573D features include ignition timing control, constant lamp power control, programmable full-bridge running frequency, programmable over and under-voltage protection and programmable over-current protection. Advanced protection features such as failure of a lamp to ignite, open load, short-circuit and a programmable fault counter have also been included in the design.
IRS2573D主要特性:
Buck, full-bridge and lamp control in one IC
Continuous/critical-conduction mode buck control
600V high and low-side full-bridge driver
600V high-side buck Driver
Low-side ignition FET gate driver
Integrated bootstrap FETs for full-bridge high-side drivers
Constant lamp power control
查看全文
