IR iP1837高效全集成DC电源解决方案
关键词:电源管理 DC/DC转换器
时间:2011-03-17 11:41:04       作者:IR       来源:iP1837
IR 公司的iP1837 iPOWIRTM是容易使用的高效全集成DC/DC电源稳压器,集成的PWM控制器和MOSFET使iP1837成为节省面积和高效的解决方案.开关频率从250kHz到1.5MHz可编程,输入电压1.5V-16V,输出电压0.6V到0.75xVIN,基准电压精度0.5%,可编软起动,主要用在服务器,网络设备,嵌入式通信设备和分布式PLO电源架构.本文介绍了iP1837主要特性, 简化方框图, 基本应用电路图以及多种典型应用电路, iP1837参考设计板主要特性,电路图和材料清单(BOM).
The iP1837 iPOWIRTM is an easy‐to‐use, fully integrated and highly efficient DC/DC regulator. The onboard PWM controller and MOSFETs make iP1837 a space‐efficient
solution, providing accurate power delivery for low output voltage and high current applications.
iP1837 is a versatile regulator which offers programmability of switching frequency and current limit while operating in wide input and output voltage range.
The switching frequency is programmable from 250kHz to 1.5MHz for an optimum solution.
It also features important protection functions, such as Pre‐Bias startup, hiccup current limit and thermal shutdown to give required system level security in the event of fault conditions.
iP1837主要特性:
Wide input application 1.5V―16V
Single 3.3V or single 5V application
Output Voltage Range: 0.6V to 0.75*Vin
0.5% accurate Reference Voltage
查看全文
