Linear LTC6803第二代电池监视解决方案
关键词:电源管理 电池监视
时间:2011-02-24 09:51:32       作者:Linear       来源:LTC6803
Linear 公司的LTC6803是第二代完整的电池监视器,包括有12位ADC,精密的基准电压,高电压输入复接器和1MHz串行接口。具有可堆栈的架构,每个器件可测试多达12个串接的电池或超级电容,总测试误差最大为0.25%,主要用于电力和混合动力汽车,大功率手持设备,备用电池系统和电动自行车,摩托车等。本文介绍了LTC6803主要特性,方框图,典型应用框图以及96节电池监视电路图和硬件关断电路方框图。
The LTCR6803 is a 2nd generation, complete battery monitoring IC that includes a 12-bit ADC, a precision voltage reference, a high voltage input multiplexer and a serial interface. Each LTC6803 can measure up to 12 series connected battery cells or supercapacitors. Many LTC6803 devices can be stacked to measure the voltage of each cell in a long battery string. Each LTC6803-2/LTC6803-4 has an individually addressable serial interface, allowing up to 16 LTC6803-2/LTC6803-4 devices to interface to one control processor and operate simultaneously. Each cell input has an associated MOSFET switch for discharging overcharged cells. The LTC6803-2 connects the bottom of the stack to V– internally. It is pin compatible with the LTC6802-2, providing a drop-in upgrade. The LTC6803-4 separates the bottom of the stack from V–, improving cell 1 measurement accuracy.
查看全文
