NXP TFA9881 3.4W PDM D类音频放大方案
关键词:消费类电子 D类音频放大器 PDM 手机 PDA PND
时间:2011-01-21 09:55:50       作者:NXP       来源:TFA9881
NXP 公司的TFA9881是 3.4W 脉冲密度调制(PDM)输入D类音频放大器,它的输入接口是过取样的脉冲密度调制(PDM)码流,通过该接口接收音频和控制设定如静音,增益,脉宽调制(PWM)输出斜率,剪辑控制和扩展带宽.工作电压2.5V-5.5V,对于4欧姆/20uH的负载效率高达90%,输出噪音电压24uV,信噪比为103dB,主要用在手机,PDA,手提游戏机,PND,笔记本电脑/上网本以及MP3播放器/PMP等.本文介绍了TFA9881主要特性和优势,方框图和典型的立体声应用电路.
TFA9881: 3.4 W PDM input class-D audio amplifier
The TFA9881 is a mono, filter-free class-D audio amplifier in a 9-bump WLCSP (Wafer
Level Chip-Size Package) with a 400um pitch.
The digital input interface is an over-sampled Pulse Density Modulated (PDM) bit stream.
The TFA9881 receives audio and control settings via this interface. Dedicated silence patterns are used to configure the control settings of the device, such as mute, gain, Pulse Width Modulated (PWM) output slope, clip control and bandwidth extension (this control mechanism is not required if the default settings are used). The Power-down to Operating mode transition is triggered when a clock signal is detected.
查看全文
