iWatt iW3610可调光数控14.7W LED驱动解决方案
关键词:电源管理 AC/DC转换器 LED驱动器
时间:2011-01-14 09:41:56       作者:iWatt       来源:iW3610
iWatt公司的iW3610是用于可调光的LED驱动器的AC/DC数字电源控制器,隔离AC/DC离线100Vac/230 Vac输入,火线频率从47Hz到64Hz,混合调光方案,调光范围从2%到100%,LED没有可见的闪烁,LED电流调整± 5%,快速起动,起动电流10uA,功率高达45W,具有多种LED保护特性.本文介绍了iW3610主要特性, 方框图, 典型应用电路图和14.7W(21V/700mA)可调光离线LED驱动器参考设计主要特性,电路图,材料清单.
iW3610: AC/DC Digital Power Controller for Dimmable LED Drivers
The iW3610 is a high performance AC/DC offline power supply controller for dimmable LED luminaires, which uses advanced digital control technology to detect the dimmer type and phase. The dimmer conduction phase controls the LED brightness. The LED brightness is modulated by PWM-dimming. The dimming frequency is selectable via product options. iW3610’s unique digital control technology eliminates visible flicker.
iW3610 can operate with all dimmer schemes including: leading-edge dimmer, trailing-edge dimmer, as well as other dimmer configurations such as R-type, R-C type or R-L type. When a dimmer is not present, the controller can automatically detect that there is no dimmer.
查看全文
