Linear LTC3511高压开关稳压电源解决方案
关键词:电源管理 DC/DC转换器
时间:2010-12-28 10:32:05       作者:Linear       来源:LTC3511
Linear 公司的LTC3511是高压单片开关稳压电源,主要为隔离的反激拓扑而设计.输入电压4.5V到100V,输出功率达2.5W,器件集成了240mA/150V的功率开关,不需要变压器的第三个绕组或光隔离器,也不需要外接起动电阻,主要用在隔离的通信电源,家庭电源和隔离的工业,汽车和医疗电源.本文介绍了LTC3511主要特性,方框图,以及多种典型的应用电路.
The LT3511 is a high voltage monolithic switching regulator specifically designed for the isolated flyback topology.
No third winding or opto-isolator is required for regulation as the part senses output voltage directly from the primary-side flyback waveform. The device integrates a 240mA, 150V power switch, high voltage circuitry, and control into a high voltage 16-lead MSOP package with four leads removed.
The LT3511 operates from an input voltage range of 4.5V to 100V and delivers up to 2.5W of isolated output power. Two external resistors and the transformer turns ratio easily set the output voltage. Off-the-shelf transformers are available for several applications. The high level of integration and the use of boundary mode operation results in a simple, clean, tightly regulated application solution to the traditionally tough problem of isolated power delivery.
LTC3511主要特性:
4.5V to 100V Input Voltage Range
Internal 240mA, 150V Power Switch
查看全文
