ST LIS331DLH 3轴MEMS运动传感器解决方案
关键词:工业控制 MEMS 传感器
时间:2010-12-14 09:59:19       作者:ST       来源:LIS331DLH
ST公司的LIS331DLH是超低功耗高性能3轴数字加速度计,动态可选择的满刻度为±2g/±4g/±8g ,16位输出数据速率从0.5 Hz 到1 kHz ,I2C/SPI数字输出接口,工作电压2.16V-3.6V,超低功耗模式功耗可低到10uA,6D取向检测,能抗10000g震动,主要用在自由跌落检测,游戏和虚构输入设备,震动监视和补偿,显示器取向,计步器等.本文介绍了LIS331DLH主要特性,方框图,电连接以及STEVAL-MKI022V1演示板主要特性,电路图和材料厂清单(BOM).
MEMS motion sensor: Ultra low power high performance 3-axis digital accelerometer
The LIS331DLH is an ultra low-power high performance three axes linear accelerometer belonging to the "nano" family, with digital I2C/SPI serial interface standard output.
The device features ultra low-power operational modes that allow advanced power saving and smart sleep to wake-up functions.
The LIS331DLH has dynamically user selectable full scales of ±2g/±4g/±8g and it is capable of measuring accelerations with output data rates from 0.5 Hz to 1 kHz.
The self-test capability allows the user to check the functioning of the sensor in the final application.
The device may be configured to generate interrupt signal by inertial wake-up/free-fall events as well as by the position of the device itself.
Thresholds and timing of interrupt generators are programmable by the end user on the fly.
查看全文
