关键词:工业控制 马达驱动 PLC 变频器 HVAC 医疗设备 计算机外设
时间:2010-11-17 11:14:23 作者:ST 来源:STM32F103xx
ST公司的STEVAL-CCM001V2图像解决方案是采用STM32F103xC,STM32F103xD或STM32F103xE 32位MCU,采用ARM® Cortex™-M3 RISC内核,工作频率72MHz,具有256-512KB闪存,USB.CAN以及格1个定时器,3个ADC和13个通信接口,工作电压2.0到3.6V,工作温度–40到+105℃,主要用在马达驱动和应用控制,医疗和手持设备,PC外设和GPS平台,工业应用,PLCV,变频器,打印机和扫描仪以及告警系统,视频互连和HVAC.本文介绍了STM32F103xC,STM32F103xD和STM32F103xE主要特性,方框图,时钟树和电源方案,以及STEVAL-CCM001V2图像演示板主要特性和电路图.
The STM32F103xC, STM32F103xD and STM32F103xE performance line family incorporates the high-performance ARM® Cortex™-M3 32-bit RISC core operating at a 72 MHz frequency, high-speed embedded memories (Flash memory up to 512 Kbytes and SRAM up to 64 Kbytes), and an extensive range of enhanced I/Os and peripherals connected to two APB buses. All devices offer three 12-bit ADCs, four general-purpose 16-bit timers plus two PWM timers, as well as standard and advanced communication interfaces: up to two I2Cs, three SPIs, two I2Ss, one SDIO, five USARTs, an USB and a CAN.
The STM32F103xx high-density performance line family operates in the –40 to +105 ℃temperature range, from a 2.0 to 3.6 V power supply. A comprehensive set of power-saving mode allows the design of low-power applications.
The STM32F103xx high-dens..
分享到:
