NXP EM773 8(16)位智能电表解决方案
关键词:消费类电子 智能电表 ARM MCU
时间:2010-10-14 10:43:13       作者:NXP       来源:EM773
NXP 公司的EM773是基于ARM Cortex-M0的低功耗32位智能电表集成电路,CPU频率高达48MHz,具有丰富外设包括多达32KB标闪存,多达8KB数据存储器,一个Fast-mode PlusI2C总线接口,一个RS-485/EIA-485 UART,一个带SSP特性的SPI接口,三个通用计数器/定时器,多达25个GPIO,以及用于电能测量的测量引擎。本文介绍了EM773主要特性和优势,方框图,智能电表原理方框图,电表主要元件BOM以及智能电表无线插头电表电路图和电表指标。
EM773:Energy metering IC; up to 32 kB flash and 8 kB SRAM
The EM773 is an ARM Cortex-M0 based, low-cost 32-bit energy metering IC, designed for 8/16-bit smart metering applications. The EM773 offers programmability and on-chip metrology functionality combined with a low power, simple instruction set and memory addressing with reduced code size compared to existing 8/16-bit architectures.
The EM773 operates at CPU frequencies of up to 48 MHz.
The peripheral complement of the EM773 includes up to 32 kB of flash memory, up to 8 kB of data memory, one Fast-mode Plus I2C-bus interface, one RS-485/EIA-485 UART,one SPI interface with SSP features, three general purpose counter/timers, up to 25 general purpose I/O pins, and a metrology engine for energy measurement.
EM773主要特性和优势:
System:
ARM Cortex-M0 processor, running at frequencies of up to 48 MHz.
查看全文
