NS LM5119双路DC-DC 20A电源控制方案
关键词:电源管理 DC/DC转换器
时间:2010-09-25 10:17:02       作者:NS       来源:LM5119
NS 公司的LM5119是双路同步电流模式降压控制器,工作电压从5.5V到65V,开关频率从50kHz 到 750kHz,具有强固的3.3A峰值栅极驱动器,可编程输出从0.8V起到输入电压的90%,输出电流高达20A,主要用在需要精密电压稳压器如通信,汽车电子以及工业控制应用。本文介绍了LM5119主要特性,方框图,典型应用电路图和LM5119EVAL评估板主要特性,电路图和材料清单(BOM)。
The LM5119 is a dual synchronous buck controller intended for step-down regulator applications from a high voltage or widely varying input supply. The control method is based upon current mode control utilizing an emulated current ramp.
Current mode control provides inherent line feed-forward, cycle- by-cycle current limiting and ease of loop compensation. The use of an emulated control ramp reduces noise sensitivity of the pulse-width modulation circuit, allowing reliable control of very small duty cycles necessary in high input voltage applications.
查看全文
