Avago ADNS-7630 LaserStream蓝牙导航传感方案
关键词:计算机及外设 蓝牙 光学鼠标
时间:2010-09-19 11:11:12       作者:Avago       来源:ADNS-7630
Avago公司的 ADNS-7630 集成了Bluetooth (BT) 2.1的系统级芯片(SoC)LaserStream导航传感器,和 Bluetooth HID外形V1.0以及蓝牙指标V2.1兼容,并且和IEC/EN 60825-1 Class 1眼安全兼容,30吋/秒高速运动检测,加速度高达8g,支持多达10个I/O引脚,4轴传感器旋转0°, 90°, 180° 或 270°,分辨率可编程从250-3000点/吋(cpi),每步增量250cpi,主要用在蓝牙无绳激光鼠标和集成输入设备。本文介绍了ADNS-7630主要特性,方框图以及应用电路图
ADNS-7630:BT SoC LaserStream™ Sensor
ADNS-7630 is the world’s first one-chip Bluetooth (BT) 2.1 System-on-Chip (SoC) LaserStream navigation sensor chip for laser-illuminated navigation system Driven by Avago’s LaserStream navigation technology and proprietary optimized cum efficient RF transceiver architecture, it provides a fully integrated and feature-rich navigation system for wireless mouse applications and other integrated input devices. This compact, laser navigation sensor engine from Avago, integrates a BT transceiver, stand-alone baseband processor and VCSEL illumination into a single chip package to provide a complete SoC solution that provides fast and secure connectivity, and easy integration into mouse designs.
ADNS-7630 complies with Bluetooth specification version 2.1 and HID profile version 1.0. The built-in radio provides low-power, low-cost and robust communications for  applications operating in the 2.4-GHz unlicensed ISM band.
Additionally, this new laser sensor has several features that can be configured via an external EEPROM to simplify mouse and provide flexibility for product customization.
This chip is available in 58-pin custom designed QFN package and designed to be used with the ADNS-7100-001 laser mouse lens to achieve the optimum performance featured in this document. These parts provide a complete and compact navigation system with no moving parts and precise optical alignment to facilitate high volume assembly. Avago has pre-calibrated the laser power prior shipment to meet IEC/EN 60825-1 Class 1 Eye Safety Standard, thus no laser power calibration is required at manufacturer site, therefore reducing assembly time and associated cost.
ADNS-7630主要特性:
One-chip Bluetooth SoC LaserStream navigation sensor optimized for laser mouse performance
Bluetooth HID profile version 1.0 compliant.
Bluetooth specification version 2.1 compatible.
Compliance to IEC/EN 60825-1 Class 1 Eye Safety
Fast data transmission through synchronized timing between sensor and Bluetooth system
Extended battery life with low power architecture and LaserStream navigation technology
– Extended inquiry response to enable fast discovery of device and to reduce latency
– Sniff Sub Rating to reduce power consumption for HID.
– Secure Simple Pairing, which supports “Just Works” and to enhance ease of use user experience.
– Encryption Pause Resume where better protection through encryption key refreshed during long connection period of use.
Excellent receiver sensitivity
Optimized Adaptive Frequency Hopping (AFH) to minimize interference disturbance
Programmable output power control meets Bluetooth Power Class 2 or Class 3 requirements
On-chip Power On Reset (POR)
High speed motion detection at 30 inches per second (ips) & acceleration up to 8g
Support up to 10 I/O pins for flexible configuration
– 3-key or 5-key mouse
– LED indicators
– Media buttons for audio control
– KeyMap (KM) for keyboard shortcut key (supported in Bluetooth version 2.0 only)
Mechanical and optical Z-Wheel interface for vertical scroll
Tilt-Wheel function for horizontal scroll
12-bit Bluetooth HID motion data reporting
Customizable SDP Service Name, Service Description, Provider Name, VID, PID, & Bluetooth Address
4-axis sensor rotations: 0°, 90°, 180° or 270°
Resolution:
– Programmable from 250-3000 counts per inch (cpi) with 250cpi incremental step
– Up to 10 selections of On-the-Fly (OTF) resolution mode setting
ADNS-7630应用:
Bluetooth cordless laser mice
Integrated input devices
图1。ADNS-7630方框图(1)
图2。ADNS-7630方框图(2)
图3。ADNS-7630应用电路图
详情请见:
http://www.avagotech.com/docs/AV02-2504EN
