Silabs Si4312 OOK CMOS RF接收器方案
关键词:消费类电子 无线遥控器 STB 玩具
时间:2010-08-13 10:54:46       作者:Silabs       来源:Si4312
Silabs 公司的Si4312 是全集成OOK CMOS RF接收器,工作在无许可证的315MHz-433.92MHz UHF频段。可选择的载波频率315/433.92 MHz,支持OOK调制,支持具16MHz晶振,有高的灵敏度–110 dBm @ 1.0 kbps,数据速率高达10 kbps NRZ,主要用在卫星STB接收器,遥控,IR替代,车库和门开启,无钥匙进入,无线POS和玩具等。本文介绍了Si4312主要特性,方框图,功能方框图,OOK 433.92 MHz应用电路图与材料清单(BOM)以及Si4312-DEMO板主要特性,电路图和Si4312-DEMO板材料清单。
The Si4312 is a fully-integrated OOK CMOS RF receiver that operates in the unlicensed 315 and 433.92 MHz ultra high frequency (UHF) bands. It is designed for high-volume, cost-sensitive RF receiver applications, such as set-top box RF receivers, remote controls, garage door openers, home automation, security, remote keyless entry systems, wireless POS, and telemetry. The Si4312 offers industry-leading RF performance, high integration, flexibility, low BOM, small board area, and ease of design. No production alignment is necessary as all RF functions are integrated into the device.
Si4312主要特性:
Single chip receiver with only six external components
Selectable 315/433.92 MHz carrier frequency
Supports OOK modulation
High sensitivity (–110 dBm @ 1.0 kbps)
Frequency scanning
查看全文
