Micrel MIC2166自适应降压电源控制方案
关键词:电源管理 DC/DC转换器
时间:2010-08-06 09:59:13       作者:Micrel       来源:MIC2166
Micrel 公司的MIC2166是同步自适应降压电源控制器,工作电压4.5V到28V,工作频率600kHz,输出电流高达25A,输出电压可调低至0.8V,精度±1%。主要用于STB,网关,路由器和DSL调制解调器,打印机,扫描仪,图像和视频卡,服务器,PC和处理器核电源以及低压分布电源。本文介绍了MIC2166主要特性,方框图,应用电路以及8V-24V 到1.2V/10A评估板电路图和评估板材料清单(BOM)。
The Micrel MIC2166 is a synchronous adaptive on-time buck controller targeting high performance, cost sensitive applications such as set-top boxes, gateways, routers, computing peripherals, and telecom/networking equipment.
The MIC2166 operates over a supply range of 4.5V to 28V. It has an internal linear regulator which provides a regulated 5V supply to power the internal control circuitry.
MIC2166 operates at a constant 600kHz switching frequency and can be used to drive up to 25A of output current. The output voltage is adjustable down to 0.8V.
查看全文
