Altera Arria II GX FPGA开发方案
关键词:通信技术 无线通信 有线通信 Arria II FPGA
时间:2010-07-26 11:05:43       作者:Altera        来源:Arria II GX
本文介绍了Arria II GX FPGA亮点,高速收发器特性,Arria II GX FPGA架构以及Arria II GX FPGA 开发套件主要特性,开发板方框图,详细的开发板电路图和材料清单(BOM)。
Arria II FPGAs: Cost-Optimized, Lowest Power 6G Transceiver FPGAs
The Arria® II GX device family is designed specifically for ease-of-use. The cost-optimized, 40-nm device family architecture features a low-power, programmable logic engine and streamlined transceivers and I/Os. Common interfaces, such as the Physical Interface for PCI Express® (PIPE) (PCIe®), Ethernet, and DDR3 memory are easily implemented in your design with the Quartus® II software, the SOPC Builder design software, and a broad library of hard and soft intellectual property (IP) solutions from Altera®. The Arria II GX device family makes designing for applications requiring transceivers operating at up to 6.375 Gbps fast and easy.
Arria II GX FPGA亮点:
The Arria II GX device features consist of the following highlights:
■ 40-nm, low-power FPGA engine
■ Adaptive logic module (ALM) offers the highest logic efficiency in the industry
■ Eight-input fracturable look-up table (LUT)
查看全文
