Active-Semi ACT8937高效7路DC电源转换方案
关键词:电源管理 DC/DC转换器
时间:2010-07-19 14:51:33       作者:Active-Semi        来源:ACT8937
The ACT8937 is a complete, cost effective, highlyefficient ActivePMUTM power management solution, optimized for the unique power, voltagesequencing, and control requirements of the Samsung S5PC100, S5PC110 and S5PV210 processors.
This device features three step-down DC/DC converters and four low-noise, low-dropout linear regulators, along with a complete battery charging solution featuring the advanced ActivePathTM system-power selection function.
The three DC/DC converters utilize a highefficiency, fixed-frequency (2MHz), current-mode PWM control architecture that requires a minimum number of external components. Two DC/DCs are capable of supplying up to 900mA of output current, while the third supports up to 700mA. All four lowdropout linear regulators are high-performance, low-noise, regulators that supply up to 150mA, 150mA, 250mA, and 250mA, respectively.
The ACT8937 is available in a compact, Pb-Free and RoHS-compliant TQFN55-40 package.
ACT8937主要特性:
• Optimized for Samsung S5PC100, S5PC110 and S5PV210 Processors
• Three Step-Down DC/DC Converters
• Four Low-Dropout Linear Regulators
查看全文
