Radiometrix TXL2和RXL2单向无线电连接方案
关键词:通信技术 无线连接 RS232 工业控制 数据采集
时间:2010-05-05 13:24:01       作者:Radiometrix       来源:中电网
Radiometrix 公司的TXL2和RXL2模块是9600波特多路OEM无线调制解调器,工作频率为欧洲的433MHz ISM频段,提供单向无线电连接方案. TXL2/RXL2与EN 300 220-3 和EN 301 489-3 兼容,具有高质量稳定的基准晶体和低噪音合成器/VCO,以及SAW前端滤波器和多级陶瓷IF滤波,发送功率+10dBm,接收灵敏度-107dBm,主要应用在手持终端,PDA,工业远程信息处理,建筑物内环境检测和控制,远程数据采集系统,舰艇,汽车数据采集等.本文介绍了TXL2和RXL2主要特性,指标和方框图,以及和MCU直接连接框图, 通过RS232线路驱动器/接收器连接到RS232端口框图.
The TXL2 and RXL2 modules are 9600baud simplex multi channel OEM radio modems in a Radiometrix SIL standard footprint, operating on European 433MHz ISM band. The TXL2/RXL2 pair act as a transparent serial cable to attached host. Unlike raw FM radio modules (e.g. TX2A/RX2A), TXL2/RXL2 will take care of preamble, synchronisation, bit balancing and error checking along with automatic noise squelching.
The TXL2/RXL2 pair provides a one-way radio link. Provided no two devices attempt to transmit simultaneously no further restrictions on data transmission need be made, as all transmit timing, valid data identification and datastream buffering is conducted by the units. Synchronisation and framing words in the packet prevent the receiver outputting garbage in the absence of wanted RF signal or presence of interference.
查看全文
