Atmel ATA6870锂离子电池组监测方案
关键词:电源管理 锂离子电池 电池组监测
时间:2010-03-23 14:00:00       来源:Atmel
Atmel 公司的ATA6870是锂离子和NiMH多个电池组测量和监测电路,它采用12位ADC来监测电池电压和电池温度,还提供每个电池平衡充电能力。此外还集成线性稳压器,以便给MCU或外接元件供电。可处理多达16个电路(96个电池)的监测。主要用在电动汽车和混合动力汽车。本文介绍ATA6870主要特性,方框图,应用电路以及用来管理锂离子/NiMH电池的评估板方框图和电路图。
The ATA6870 is a measurement and monitoring circuit designed for Li-ion and NiMH multicell battery stacks in hybrid electrical vehicles.
The ATA6870 monitors the battery-cell voltage and the battery-cell temperature with a 12-bit ADC.
The circuit also provides charge-balancing capability for each battery-cell. In addition, a linear regulator is integrated to supply a microcontroller or other external components. Reliable communication between stacked ICs is achieved by level-shifters with current sources. The ATA6870 can be connected to three, four, five or six battery-cells. Up to 16 circuits (96 cells) can be cascaded in one string. The number of strings is not limited.
ATA6870主要特性:
• 12-bit Battery-cell Voltage Measurement
• Simultaneous Battery Cells Measurement in Parallel
• Cell Temperature Measurement
• Charge Balancing Capability
– Parallel Balancing of Cells Possible
查看全文
