Powerint TOP259LN 65W笔记本电脑电源方案
关键词:电源管理 AC/DC转换器 笔记本电脑
时间:2010-02-25 10:17:00       来源:Powerint
Powerint 公司的65W笔记本电脑用适配器是采用TOP259LN的超小型电源解决方案. 适配器采用90 VAC – 265 VAC 输入, 输出为19.7 V, 3.33 A. 230VAC无负载输入的功耗非常低,小于250mW,满足能源之星2.0的节能要求, 115 V / 60 Hz和230 V / 50 Hz的效率大于88%,具有极好的瞬态负载响应.本文介绍TOP252-262 TOPSwitch-HX系列主要特性,方框图和多种应用电路,以及65W笔记本电脑用适配器参考设计电路图和材料清单.
TOP252-262 TOPSwitch-HX Family
Enhanced EcoSmart?, Integrated Off-Line Switcher with Advanced Feature Set and Extended Power Range
TOP252-262 TOPSwitch-HX 系列主要亮点:
Lower System Cost, Higher Design Flexibility
Multi-mode operation maximizes effi ciency at all loads
New eSIP-7F and eSIP-7C packages
Low thermal impedance junction-to-case (2℃ per watt)
Low height is ideal for adapters where space is limited
Simple mounting using a clip to aid low cost manufacturing
Horizontal eSIP-7F package ideal for ultra low height adapter and monitor applications
Extended package creepage distance from DRAIN pin to adjacent pin and to heat sink
No heatsink required up to 35 W using P, G and M packages
with universal input voltage and up to 48 W at 230 VAC
查看全文
