Linear LT3492三输出恒流源LED驱动方案
关键词:电源管理 LED驱动器
时间:2010-01-05 10:57:00       来源:Linear
Linear 公司的LT3492是三输出DC/DC转换器,可用作恒流源LED驱动器,可工作在降压,升压和降升压模式. True Color PWM™调光的调光比高达3000:1,可调频率从330kHz 到2.1MHz,工作电压从3V 到30V,瞬间保护到40V,主要用于RGB照明,大显示屏,汽车和航空照明以及恒流源.本文介绍LT3492主要特性,方框图,以及多种应用电路图.
The LTR3492 is a triple output DC/DC converter designed to operate as a constant-current source and is ideal for driving LEDs. The LT3492 works in buck, boost or buckboost mode. The LT3492 uses a fixed frequency, current mode architecture resulting in stable operation over a wide range of supply and output voltages. A frequency adjust pin allows the user to program switching frequency between 330kHz and 2.1MHz to optimize efficiency and external component size.
The external PWM input provides 3000:1 LED dimming on each channel. Each of the three channels has a built-in gate driver to drive an external LED-disconnect P-channel MOSFET, allowing high dimming range. The output current range of each channel of the LT3492 is programmed with an external sense resistor.
The CTRL pin is used to adjust the LED current either for analog dimming or overtemperature protection.
LT3492主要特性:
True Color PWM™ Dimming Delivers Up to 3000:1 Dimming Ratio
查看全文
