ST LYPR540AH MEMS三轴运动检测方案
关键词:工业控制 传感器 MEMS
时间:2009-11-24 10:34:00       来源:ST
ST 公司的LYPR540AH 是MEMS运动传感器,三轴模拟输出陀螺仪, 具有偏航,倾斜和滚动模拟陀螺仪特性,三轴有单独的输出通路. LYPR540AH提供放大(±400 dps满刻度)和不放大(±1600 dps满刻度)输出,-3dB带宽检测速率高达140 Hz,模拟工作电压2.7 V 到 3.6 V,主要用在运动和人机接口,健身设备,遥控制器,工业和机器人,个人导航设备.本文介绍LYPR540AH主要特性,方框图和应用电路图.
LYPR540AH: MEMS motion sensor: 3 axis analog output gyroscope
The LYPR540AH is a three axis yaw, pitch and roll analog gyroscope featuring three separate analog output channels.
LYPR540AH provides amplified (±400 dps full scale) and not amplified (±1600 dps full scale) outputs for each sensible axis available at the same time through dedicated pins, and is capable of detecting rates with a -3 dB bandwidth up to 140 Hz.
ST 3 axis gyroscope family leverages on robust and mature manufacturing process already used for the production of hundreds million micromachined accelerometers with excellent acceptance from the market.
Sensing element is manufactured using specialized micromachining processes, while the IC interfaces are realized using a CMOS technology that allows to design a dedicated circuit which is trimmed to better match the sensing element characteristics.
查看全文
